This M272 engine (#30-061884) uses the older style 2 piece timing chain tensioner....the style with an end cap. Due to occasional hot start timing chain rattle, I want to replace the tensioner. Are there any special installation requirements like crank position etc. as with the newer style tensioner (crank at 40 degrees)? The WIS isn't clear about this. There are no codes or check engine light. Thank you.
Sep 26, 2025 at 5:55 AM
