Hi, I was given the vehicle listed above with a bunch of brand-new parts, including a complete distributor assembly, new timing chain with two gears. timing cover/gasket, oil pan gasket, SPs and SP wire set, filters, radiator and two hoses, etc. I saw you guys working on 4.3s on your YouTube channel! There's no distributor in it, just a rag over the hole. Plans: set the thing at TDC on the compression stroke by sticking something in the #1 SP hole, remove radiator/hoses, remove fan/serpentine belt, drain oil/remove pan, remove whatever else in the way, remove timing chain cover, chain and two gears (no tensioner for this model!). The finer details are what i need to know, like putting the motor gear marks down (if it's at perfect TDC already, they should be there, right?) Then new TC gear dimples point to each other? Please give me your wisdom on anything that generally goes wrong here! For reassembly, what do i put on the new TC gasket to ensure it does not leak the first time? (i know to carefully, slowly, and evenly tighten the TC cover bolts a little at a time.) I know how to install the dizzy and get the oil pump gear lined up just fine. Just tell me some Murphy's law ideas about this.
Oct 18, 2022 at 5:55 AM
