Yeah. That is what I normally do is lock the cams so that are held in place but if you think about it, once the engine is locked down and you remove the chain, it doesn't matter what position it is in as long as the chain goes back on without it moving. So if you align the cams or crank so that you can get the chain in the correct position and then the engine doesn't move until the new chain is installed, then the engine will remain in time.
A lot of people think they need to set the engine in time then remove the chain. That is fine but the engine is already in time so you just need an orientation point which would be the cam or crank and then you can lock it down and put the new chain on and it remains in the same position.
The only times you need to re-time the engine is when the chain skipped or broke or the engine moved when the chain was removed.
Hope that helps. Thanks
Apr 3, 2021 at 10:20 AM
