The check engine light came on and the vehicle started idling hard. I had an engine diagnostic done. It reads found codes P0300, random misfire (cylinders 2 and 4 are constantly misfiring other cylinders are intermittent) P0018,
Crankshaft position/camshaft correlation (B2SA). C1208, L/R wheel speed sensor air gap. C1211, R/R wheel speed sensor air gap. C1513, Brake Switch. We suspect the timing jumped teeth by camshaft.
Do I need a new timing chain or engine?
Oct 20, 2023 at 4:16 PM
