That could be a timing chain but that does sound more like a bearing knock.
Have you drained the oil and checked for metal?
https://www.2carpros.com/articles/how-to-change-engine-oil-and-filter
Before you go to the point of pulling the cover off and check the tensioner off, because that is pretty extensive, I would try to identify if this is a bearing noise.
The fact that it gets louder on acceleration could be a timing chain, but they normally get louder on deceleration. So, when you take the tension off the chain it slaps the cover.
However, this noise sounds like it is starting on accel and then it continues rattling on deceleration.
So, the best way to try and get a better idea is to bring the RPMs up and hold it to see if the rattle is there. Then let off and if it continues then it is most likely crank bearings.
However, if it doesn't really start when holding higher RPMs (not floored but about 2,500) then as soon as you let off it starts then that would most likely be a timing chain.
If it is, then basically you are going to have to replace it. There are no TSBs or any known issues that I know of.
So, let's start with draining the oil to look for metal and see if the noise is there when holding the RPMs.
May 17, 2022 at 7:09 AM
