Timing chain jump
2001 MAZDA TRIBUTE
240,000 MILES • 3.0L • 4WD • AUTOMATIC
FARR2007
  • 244 POSTS
Timing chain jumped a link. how can this be fixed?
Sep 25, 2020 at 2:16 PM
Good evening,
Was the chain just replaced?
If it was not, then there is a reason for the timing to jump. Most likely you will need to replace both chains, the guides and the tensioners.
https://www.2carpros.com/articles/how-a-timing-belt-works
How far off is the timing?
I attached the diagram of the chains for you. Which gear moved and how much did it move?
I also attached a YouTube video of the timing chain replacement. The engine is out of the car but shows the procedures for replacing the chains.
https://www.youtube.com/watch?v=eS9Yd477AyQ
Sep 25, 2020 at 3:10 PM
FARR2007
  • 244 POSTS
How can i tell what link it was that jumped?
Sep 26, 2020 at 7:23 AM
You will need to remove the front cover and check the alignment marks.
Does the engine run at the moment?
Sep 27, 2020 at 7:13 AM
