I’m doing a timing chain replacement on a 2007 5.4l, I have all the roller followers out and I have installed the new chains, phasers, guides and tensioners. Is it ok to go ahead and turn the crankshaft to get the cams in the right position to put the roller followers back in, since the chains are all right on the phasers will it keep the correct timing if I turn the crankshaft to put the followers back in . I used the tool to get the crankshaft in the correct spot to set timing to put the chains on but I know it won’t be in that spot after turning it to get all the roller followers back in
Thanks
Thanks
Aug 3, 2025 at 4:28 PM
