timing chain issues
2012 CHEVROLET TRAVERSE
120 MILES • 3.6L • V6 • 2WD • AUTOMATIC
JESSESLVN1994
  • 18 POSTS
I replaced the timing chains and phasers on my vehicle listed above and when i get done with all the chains and roll it over the chain rises up off the phasers when the tensions for the chains push back in and it jumps. everything has been aligned over and over to the correct spot. no idea what is causing this.
Sep 4, 2020 at 9:05 PM
STEVE W.
  • 15,113 POSTS
The description sounds like the sprockets are not lined up in relation to each other. Was the kit you used a GM parts kit or someone else's? I have seen this on some of the lower cost parts because they didn't machine them correctly. If it is a GM kit then you will need to check the alignment and check the chain itself to see if it has tight spots in it.
Sep 5, 2020 at 12:42 PM
JESSESLVN1994
  • 18 POSTS
I checked over everything and it has slack in chains when the tensioner compresses making it jump.
Sep 5, 2020 at 1:44 PM
STEVE W.
  • 15,113 POSTS
Is it doing it on only one side or both? You replaced the tensioners and shoes or did you use the old ones? Could you maybe shoot a video showing the issue and post it on here, it still sounds like an alignment issue with a sprocket, not a timing issue but more like a sprocket is out of line if you were to look down from on top of the engine, if the chain is riding up on them. Is it only on one or both cams? Are you rotating the engine clockwise when you check the marks? Plugs are out correct?
Sep 5, 2020 at 2:45 PM
JESSESLVN1994
  • 18 POSTS
Both sides turning clock wise and plugs are out. I will try to get a video here in next 20 minutes.
Sep 5, 2020 at 3:38 PM
JESSESLVN1994
  • 18 POSTS
I'm getting ready to redo the timing alignment. i'm in stage one timing is there where everything should be? Brand new guides as well.
Sep 5, 2020 at 4:03 PM
JESSESLVN1994
  • 18 POSTS
Cam flats where the cam holders go are all flat facing up right now.
STEVE W.
  • 15,113 POSTS
These are the alignment locations for the stages. Once you have everything in place and the tensioners installed you should be able to rotate the engine clockwise as the tensioners are on the slack side.
Sep 5, 2020 at 4:28 PM
JESSESLVN1994
  • 18 POSTS
I'm on stage one now and everything is exact as the pictures.
Sep 5, 2020 at 4:53 PM
JESSESLVN1994
  • 18 POSTS
Here is what it is doing getting slack on the exhaust side guide when tensioner compresses:
Sep 5, 2020 at 5:31 PM
JESSESLVN1994
  • 18 POSTS
You can see how far the black guide sucks in in the very left corner when it compress.
Sep 5, 2020 at 5:33 PM
STEVE W.
  • 15,113 POSTS
That definitely isn't correct. It almost looks like the chain and sprocket are not the same pitch. Where did you get the parts from?
Sep 5, 2020 at 7:32 PM
JESSESLVN1994
  • 18 POSTS
Parts geek says it's right part number, but seems to be the only thing it can be is the chains doesn't sit on the gears far enough so it jumps off.
Sep 5, 2020 at 7:37 PM
JESSESLVN1994
  • 18 POSTS
Here's the info:
Sep 5, 2020 at 7:43 PM
STEVE W.
  • 15,113 POSTS
It may be the correct part number but not the best quality parts. With the way the parts have been going it's hard to trust any of them anymore. I've seen some of the aftermarket kits replaced in under 10,000 because the parts were very poor quality. I try to only use the newer parts directly from GM on the 3.6 because they have updated them a few times. The current GM kit number is 12700436.
Sep 5, 2020 at 11:00 PM
JESSESLVN1994
  • 18 POSTS
Just replaced with whole new cloyes set, still does it.
Sep 9, 2020 at 3:36 PM
STEVE W.
  • 15,113 POSTS
What are the tensioners doing when you move the crankshaft? With the pins pulled they should apply tension to the chain and seat the teeth into the sprocket. Also if you try to rotate the cam with the chain off is it free to move some? This engine was running okay prior to this correct? It didn't jump time or break a chain first?
Sep 9, 2020 at 5:31 PM
JESSESLVN1994
  • 18 POSTS
Tensioners are going out then when they go in slack in chain and pops up off sprocket. yes, there is play to move the cams when chain is off.
Sep 9, 2020 at 6:30 PM
STEVE W.
  • 15,113 POSTS
What was the reason for the repair? Timing codes, chain damage? I cannot think of anything that would really cause this issue if the parts are correct unless the tensioner is not holding as it should. When the pin was released it should have ratcheted out and locked. Then once the engine starts oil pressure acts on it and will tighten it as needed. Is it only the tensioner that is moving or are the guides flexing? Did the kit include new tensioners or are you using the old ones? If they are the old ones how did you retract them? If new you may want to take it apart and see if it is assembled correctly. It shouldn't retract easily once it extends.
Using the second image I posted above of the chains in position do they match up with this stage 2 list?
1 - Left Intake Camshaft Position (CMP) Actuator Timing Mark- Circle
2 - Left Intake Secondary Camshaft Timing Drive Chain Timing Link
3 - Left Exhaust Secondary Camshaft Timing Drive Chain Timing Link
4 - Left Exhaust Camshaft Position (CMP) Actuator Timing Mark- Circle
5 - Left Secondary Camshaft Timing Drive Chain
6 - Primary Camshaft Drive Chain Timing Link for the Left Primary Camshaft Intermediate Drive Chain Sprocket
7 - Left Primary Camshaft Intermediate Drive Chain Sprocket Timing Mark for the Primary Camshaft Drive Chain
8 - Left Primary Camshaft Intermediate Drive Chain Sprocket
9 - Left Secondary Camshaft Timing Drive Chain Timing Link for the Left Primary Camshaft Intermediate Drive Chain Sprocket, behind hole in sprocket
10 - Left Primary Camshaft Intermediate Drive Chain Sprocket Timing Window
11 - Primary Camshaft Drive Chain
12 - Primary Camshaft Drive Chain Timing Link for the Crankshaft Sprocket
13 - Crankshaft Sprocket Timing Mark
14 - Crankshaft Sprocket
15 - Right Primary Camshaft Intermediate Drive Chain Sprocket
16 - Primary Camshaft Drive Chain Timing Link for the Right Primary Camshaft Intermediate Drive Chain Sprocket
17 - Right Primary Camshaft Intermediate Drive Chain Sprocket Timing Mark for the Primary Camshaft Drive Chain
18 - Right Primary Camshaft Intermediate Drive Chain Sprocket Timing Mark/Window for the Right Secondary Camshaft Timing Drive Chain
19 - Right Secondary Camshaft Timing Drive Chain Timing Link for the Right Primary Camshaft Intermediate Drive Chain Sprocket
20 - Right Secondary Camshaft Timing Drive Chain
21 - Right Exhaust Camshaft Position (CMP) Actuator Timing Mark- Triangle
22 - Right Exhaust Secondary Camshaft Timing Drive Chain Timing Link
23 - Right Intake Secondary Camshaft Timing Drive Chain Timing Link
24 - Right Intake Camshaft Position (CMP) Actuator Timing Mark- Triangle
Also try rotating the engine the other direction and see if the chain stays tight, just to see if there is a different problem. Keep in mind that on this engine you set the chains in position, release the tensioner and then button it up. Rotating the engine to verify timing positions isn't normally done on that engine as the chains are all different and won't line up again. However the tensioner still shouldn't pop in like that.
Sep 10, 2020 at 10:41 AM
JESSESLVN1994
  • 18 POSTS
Okay, so it was misfiring around 55 not bad but had engine light on for timing chains and they were stretched. It ran and drove fine. first kit off parts geek came with everything new even tensioners and it did that just bought another complete cloyes kit including tensioners all new again the tensioners will not lock they will compress and extend as rotated. i deactivated the tensioners and put pin back in when i assembled them and pulled pin they extend until chain is tight on tensioners side, but when rotated it compresses and slacks the chain on the exhaust side causing it to ride up on the teeth and jump. they will not lock as they are the ladder design and hydraulic pressure is not behind them yet?
Sep 10, 2020 at 11:06 AM
JESSESLVN1994
  • 18 POSTS
And yes all the chains line up but when rotated jump.
Sep 10, 2020 at 11:16 AM
STEVE W.
  • 15,113 POSTS
The newer design needs oil pressure to lock them but they shouldn't retract like that either. I would take a close look at the path the chain is taking and the sprockets as well. It's acting like the chain is binding down below the guide. The problem is that the oil pressure takes a second or two to reach the tensioner so if it jumps now it could easily jump when you try to start it. As a test try sticking something in between the guide and the tensioner position and see if it stays tight that way. You should be able to tell if something is binding that way.
Sep 10, 2020 at 12:23 PM
JESSESLVN1994
  • 18 POSTS
It does stay on the sprocket when you hold the tension-er out.
Sep 10, 2020 at 12:47 PM
STEVE W.
  • 15,113 POSTS
Well that's a good thing. Take a look at this video and see if it looks like what you have done. I think I'm missing something but not sure what.
https://www.youtube.com/watch?v=1SC8Jy9NOJk
Sep 10, 2020 at 6:47 PM
JESSESLVN1994
  • 18 POSTS
Yes, i watched that video before i started on it.
Sep 10, 2020 at 7:16 PM
STEVE W.
  • 15,113 POSTS
Okay, I asked a couple others and we all came up with the same thing. This engine gets put together, then the timing cover goes on and it is tight enough that the chain should stay in place on initial start. To check that one suggested setting it all up, mark the chains in a couple places, now put the covers on with only a couple bolts and rotate the engine some, see if the chain stays then. I know the GM info I've read doesn't mention trying to rotate the engine like you do many others.
Sep 12, 2020 at 9:19 AM
