One thing to be aware of if you disconnect the battery as instructed, the engine's idle speed will be too low. It may not start unless you hold the accelerator pedal down 1/4". It will not give the nice "idle flare-up" to 1500 rpm at startup, and it will tend to stall at stop signs. All other learned sensor personalities and fuel trim numbers will be relearned as soon as you start the engine. The one notable exception is "minimum throttle". Once that is relearned, idle speed will be back to normal.
To meet the conditions for that relearn to occur, drive at highway speed with the engine warmed up, then coast for at least seven seconds without touching the pedals.
Apr 18, 2023 at 6:21 PM
