Timing chain cover
1998 SATURN SW2
300,000 MILES • 1.9L • 4 CYL • 2WD
UNCLEBIFF
  • 37 POSTS
When I removed the timing chain cover the piece where the pulley bolts on seems to have broke off. Is it replaceable?
Nov 25, 2018 at 12:52 PM
Good afternoon,
Can you post a picture of what you see?
Do you mean the tension-er or the cam or crank pulley?
Nov 25, 2018 at 1:04 PM
UNCLEBIFF
  • 37 POSTS
This is front and back view it looks like some kind of insert. I do not know if it is factory.
Nov 25, 2018 at 2:02 PM
Okay, that is for the pulley for the drive belt.
Yes, replace the cover. You would be much better off getting that new part.
You can call a gm dealer for the part as Saturn is under the GM umbrella.
Nov 25, 2018 at 2:30 PM
