Timing chain slips
2015 CHEVROLET IMPALA
114,000 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
BRANDON CORNELL
  • 20 POSTS
My timing chain slips on left exhaust side?
Dec 2, 2019 at 2:42 PM
Good evening,
Slips? Please explain.
You have a tensioner and a guide to keep it tight. What have you done so far?
Dec 2, 2019 at 3:16 PM
BRANDON CORNELL
  • 20 POSTS
I use the cloyes video but when i go to turn it over left bank exhaust cam spins like to much slack on the guide part of chain.
Dec 2, 2019 at 4:24 PM
Okay, then most likely the timing is way off on that side from either a failed guide or tensioner.
Most likely with this issue, you may have valve damage.
Does the engine run?
Dec 2, 2019 at 5:18 PM
BRANDON CORNELL
  • 20 POSTS
Yes it runs. i cut it off when i heard it back fire.
Dec 2, 2019 at 7:36 PM
BRANDON CORNELL
  • 20 POSTS
Probably going to buy the Cloyes timing chain and compression check it.
Dec 2, 2019 at 7:37 PM
Keep us updated. I attached a YouTube video of the procedure.
https://www.youtube.com/watch?v=hZyehWKDV-Y
Dec 3, 2019 at 4:42 AM
BRANDON CORNELL
  • 20 POSTS
Okay, i will.
Dec 3, 2019 at 5:58 AM
Have a good day.
Dec 3, 2019 at 5:59 AM
BRANDON CORNELL
  • 20 POSTS
Took it a loose today and it's a lot of slack on the secondary chain (brand new) exhaust phaser going down the guide. but the tensioner side stays tight. could it be because i got it off Amazon for $140.00? but my Cloyes chain well be here Thursday.
Dec 3, 2019 at 3:03 PM
You either have a guide or tensioner that is causing the slack. That is not normal.
Can you post some pictures?
Dec 3, 2019 at 3:06 PM
BRANDON CORNELL
  • 20 POSTS
Okay, i will tomorrow.
Dec 3, 2019 at 3:18 PM
Sounds good.
Dec 3, 2019 at 3:26 PM
BRANDON CORNELL
  • 20 POSTS
Slips on both sides.
Dec 4, 2019 at 12:46 PM
BRANDON CORNELL
  • 20 POSTS
Think it's this chain:
Dec 4, 2019 at 12:49 PM
Okay, is the tensioner fully extended?
Dec 4, 2019 at 12:52 PM
BRANDON CORNELL
  • 20 POSTS
Nope only only when there's slack to that side.
Dec 4, 2019 at 3:09 PM
BRANDON CORNELL
  • 20 POSTS
The tensioner side is tight and the guide side is loose.
Dec 4, 2019 at 3:10 PM
BRANDON CORNELL
  • 20 POSTS
Then vice versa.
Is the tensioner fully extended? If it is, it will take up all the slack in the chain, not just on one side. Sounds like you have a bad tensioner.
Dec 4, 2019 at 3:17 PM
BRANDON CORNELL
  • 20 POSTS
Not strong enough to pull against the idler since its on crank and not enough to pull against cam but this me turning it over by hand so I think your right
Dec 4, 2019 at 4:35 PM
Yep
Dec 4, 2019 at 4:38 PM
BRANDON CORNELL
  • 20 POSTS
Think it was just a cheap chain didn't think $150.00 was cheap but compared to $330.00 Cloye's chain seem way tighter haven't turn it over but there's a difference in chain length Cloye's was 1/4 smaller.
Dec 5, 2019 at 4:37 PM
Hand turn the motor and check to see if it turns freely.
Dec 5, 2019 at 5:08 PM
BRANDON CORNELL
  • 20 POSTS
I will today... lets say it make 4 full turns is it fine to compression check it or do i have to start it for tensioner?
Dec 5, 2019 at 9:02 PM
It will be fine for the compression test.
Dec 5, 2019 at 9:46 PM
BRANDON CORNELL
  • 20 POSTS
Yea buddy.
Dec 6, 2019 at 2:31 AM
BRANDON CORNELL
  • 20 POSTS
Going to do it today.
Dec 6, 2019 at 2:32 AM
Keep me updated.
Dec 6, 2019 at 2:50 AM
BRANDON CORNELL
  • 20 POSTS
Brand new but bad chain was the problem.. the Cloyes is the best.. I turn it over 4-5 times its good! Thanks? Going to compression check tomorrow .
Dec 6, 2019 at 1:55 PM
Keep me updated.
Dec 7, 2019 at 8:40 AM
BRANDON CORNELL
  • 20 POSTS
Its alive! Shes running good. i am going to stick with Cloyes.
Dec 8, 2019 at 10:08 AM
Good deal.
Dec 8, 2019 at 2:50 PM
Did you post a question? I got an email but nothing showed up on my end.
Dec 10, 2019 at 2:50 PM
BRANDON CORNELL
  • 20 POSTS
Nah! Just saying thanks.
Dec 13, 2019 at 8:14 AM
You are welcome.
Always glad to help.
Dec 13, 2019 at 11:47 AM
