Starts and runs, sometimes backfires and the belt squeals often. Not entirely sure what the problem is.
Dec 17, 2017 at 11:51 AM
CERTIFIED EXPERT
Good morning my name is Roy and I will assist.
Backfiring means spark when it was not called for. check all you ignition components first. That is, plugs, wires, cap and rotor. While the plugs are out, do a compression test to verify the engine is good and it will also tell if you have a timing chain issue.
Try this and get back to us with the results.
Dec 17, 2017 at 11:07 PM
SWEYER
MEMBER
Thank you I will try that and get back to you. thank you again.
