Timing chain
1998 CHEVROLET CAVALIER
300,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
LETICIARAMOS2890
  • 56 POSTS
I just had timing chain replaced on my car. The mechanic says the vehicle starts now, but will not stay on. Also the engine is running rough and backfires. Could this be something serious? I do not know if I should try getting it fix or time to junk it. This is my only vehicle and it gets me,my daughter and grand-kids around. Help somebody.
May 24, 2016 at 5:14 PM
SATURNTECH9
  • 30,869 POSTS
Need more information like why was it changed? Also how did it run before it was changed?
May 24, 2016 at 5:58 PM
LETICIARAMOS2890
  • 56 POSTS
Vehicle was running fine until the timing chain went out on me.
May 24, 2016 at 7:04 PM
LETICIARAMOS2890
  • 56 POSTS
My daughter heard a rattling noise and the car just died out at stop light. It would not start after that.
May 24, 2016 at 7:27 PM
SATURNTECH9
  • 30,869 POSTS
Alright then when the timing chain failed the engine could have bent a valve. If the engine is timed correctly then a compression test should be performed. Didn't your mechanic suggest that when it ran so bad?
May 24, 2016 at 9:51 PM
LETICIARAMOS2890
  • 56 POSTS
No, he just said the spark plugs might need to be replaced. If you don't mind my asking what is a compression test and how do I know if he did it? I guess I am going to have to ask him to try a compression test. Anything else you might suggest. I really appreciate you input, we really need the car repaired, I am so tired of catching bus in all this rain.
May 25, 2016 at 5:12 AM
LETICIARAMOS2890
  • 56 POSTS
the engine cranks over but it will not stay on, dies out and backfires.
May 25, 2016 at 6:26 AM
SATURNTECH9
  • 30,869 POSTS
If it ran fine before unless he broke a spark plug or did not time it right or something else was not done right. Then the only other thing I can think of is when the chain failed a piston might have hit a valve and bent it. An engine draws in air to compress to make pressure for a explosion inside the engine. Then fuel is put in the pressurized combustion chamber and ignited for the explosion to make the engine rotate and make power to go down the road. If there isn't enough pressure made in some or all the cylinders those cylinders will not run or contribute power. The mechanic should know all this. Ask him if he did a compression test that checked the pressures in each cylinder. If spent take very long to do on that engine.
May 25, 2016 at 6:32 AM
LETICIARAMOS2890
  • 56 POSTS
Okay, I will do that today. Thanks again.
May 25, 2016 at 6:54 AM
Please let us know what you find out so it will help others.
May 25, 2016 at 6:45 PM
LETICIARAMOS2890
  • 56 POSTS
I sure will
May 25, 2016 at 6:57 PM
LETICIARAMOS2890
  • 56 POSTS
Can anyone help with the alignment for the timing chain,mechanic can not find them. He sees in on small gear but not the large one. I cant afford to start over and go to another mechanic. Thanks
Jun 12, 2016 at 12:19 PM
SATURNTECH9
  • 30,869 POSTS
So how did he time the engine when he changed the chain.
Jun 12, 2016 at 6:01 PM
SATURNTECH9
  • 30,869 POSTS
Here you go.
Jun 12, 2016 at 8:24 PM
LETICIARAMOS2890
  • 56 POSTS
Thank you,will have him do it today.
Jun 13, 2016 at 6:47 AM
LETICIARAMOS2890
  • 56 POSTS
Finally got my car running,now need to get my muffler replaced. Thank guys for all your help..
Jul 3, 2016 at 2:46 PM
SATURNTECH9
  • 30,869 POSTS
Your welcome so the timing when he put it all together was just off?
Jul 3, 2016 at 2:48 PM
LETICIARAMOS2890
  • 56 POSTS
Yes and power steering pump had to be replaced. Driving with temporary fix on muffler til I can save money for new one.
Jul 3, 2016 at 2:53 PM
SATURNTECH9
  • 30,869 POSTS
That sucks sounds like the guy just didn't know what he was doing.
Jul 3, 2016 at 3:03 PM
