Timing chain broke after replacing the clutch
2010 RENAULT TRAFIC
175,000 MILES • 1.9L • 4 CYL • 2WD • MANUAL
TREVOR GREENWOOD
What would cause a timing chain to jump and brake teeth after a clutch change?
Aug 13, 2018 at 1:28 PM
That is a good question. The two are not related, so the only thing I can say is either it is coincidental or it was loose and the clutch grabbing properly was enough change in the RPM's to allow it to break.
If you have pictures of the belt and broken pulley, can you upload it so I can see exactly what has happened?
Aug 14, 2018 at 8:54 PM
TREVOR GREENWOOD
If the engine was rotated anti clock wise and the tension taken off the timing chain could that have caused chain to jump and brake teeth?
Aug 15, 2018 at 6:46 AM
Hi again. Anything is possible, but that should not have caused a problem.
Aug 15, 2018 at 7:51 PM
TREVOR GREENWOOD
Thank you.
Aug 15, 2018 at 10:55 PM
Glad to help. I wish I could give you a clean cut answer, but nothing you did should have caused it to break.
Aug 16, 2018 at 6:32 PM
