Timing belt broke
1999 MAZDA B2500
175,000 MILES • 2WD • MANUAL
JAMIEGILLIAM06
Timing belt broke, we replaced the thermostat,belt,plugs and wires but the truck loses power in 4th and 5th gear and revs really high when clutch is pushed in,isbrhe timing still off
Apr 26, 2023 at 9:47 PM
Have you checked to make sure there are no engine vacuum leaks? If not, start there.
Here is a link that explains how it's done:
Here is a link you may find helpful as well:
https://www.2carpros.com/articles/engine-idles-too-high
Let me know what you find. Also, let me know if you checked for diagnostic trouble codes. If the check engine light stays on when the engine is running, there will be codes that may help.
joe
May 5, 2023 at 11:05 PM
