Timing belt and brakes
2003 MITSUBISHI OUTLANDER
130,000 MILES • 2.4L • 4 CYL • AWD • AUTOMATIC
BCMULLEN95
  • 249 POSTS
Just replaced the timing belt, the brakes no longer work like they did before. What components involved with the timing belt can effect the brakes? The brakes feel like manual brakes.
Sep 26, 2017 at 12:29 PM
How does the engine run? low power? if so then it sounds like the timing belt is off one tooth causing low vacuum.
Here is a guide so you can check out and confirm the problem:
https://www.2carpros.com/diagrams/mitsubishi/outlander/2003
Please let us know what happens and upload pictures or videos of the problem.
Sep 27, 2017 at 1:10 PM
