Timing belt broke, rebuilt engine will not start
2012 PEUGEOT PARTNER
165,000 MILES • 1.6L • MANUAL
ANDY REVILL
So timing belt snapped causing enine damage. Garage have done an engine rebuild but van still won't start. Can't do nothing until Monday. Need it sorting asap as need it for business
Oct 19, 2019 at 8:29 AM
Welcome to 2CarPros.
Many things can cause it not to start after what happened and the rebuild. There could still be a compression issue, timing may have not been set properly and so on. Do you have access to the vehicle?
If you do, record the engine cranking so I can hear it. If it is a timing or compression issue, I'll be able to tell. Next, I need to know if fuel pressure and ignition spark have been checked.
Oct 19, 2019 at 9:05 PM
ANDY REVILL
Hi Joe, many thanks for your reply. I don't have access to it right now as it's still in garage. They are going to look at it again tomorrow. Also the mechanic who did most of the work has gone on holiday. I will get in touch first thing and tell them what you have told me. Can they get in touch with you directly if need be?
Oct 20, 2019 at 2:04 AM
Welcome back:
Let me know if I can help.
Oct 20, 2019 at 9:08 PM
