Timing belt
1989 MAZDA 929
51,000 MILES • 3.0L • V6 • RWD • AUTOMATIC
RONTS
  • 12 POSTS
My vehicle with only 85,000 km on it, in mint shape. I replaced the timing belt and it ran for a week alright. My daughter drove it to a town 1.5 hours away she turned it off and the next day it would not start. I am thinking maybe timing belt jumped a few teeth. When I changed the belt I marked where crank gear was and cam sprockets marks are still the same but mark is gone off crank sprocket so I do not know if that had changed. But now how do I set it by TDC. I have a diagram that shows the arrow above the crank gear but what mark is on gear to align with is it the key slot? Also the cam gears have the dot but what mark is there on heads to align with. I am hoping that valves are not ruin now. I could really use your help on this. The car is a dream to drive and it looks brand new.
Ron
Sep 10, 2016 at 7:58 AM
HMAC300
  • 48,601 POSTS
the crank pulley is going to be hard to see as it is a screwy mark on it. I would put a paint mark on front for next time. See attached photo.
Sep 11, 2016 at 8:25 AM
RONTS
  • 12 POSTS
The crank pulley or the harmonic balancer I have off. Your diagram shows a black mark on the crank gear. I don't see this on mine. Also what mark am I looking for on heads for cam sprocket? How do I do it by TDC?
Sep 12, 2016 at 6:14 PM
HMAC300
  • 48,601 POSTS
it has to be done by TDC and the mark as I said will be very hard to see so I would suggest cleaning pulley to see it better if you can. it is not a very good system itming gear for cams are dot to dot kind of if you look at pic, click on pic to enlarge it.
Sep 13, 2016 at 6:50 AM
RONTS
  • 12 POSTS
Would this be the mark just under the arrow?
Sep 13, 2016 at 1:49 PM
HMAC300
  • 48,601 POSTS
is the piston at tdc on #1 if it is I would say yes or if no other teeth on pulley look like that i'd say yes. Like I said it's a very poor setup especially for cam timing.
Sep 13, 2016 at 3:00 PM
RONTS
  • 12 POSTS
How do I check if piston at TDC? If it is at TDC and I turn it one complete turn will it be at TDC again. If that is the mark and given that the cams are off a bit does that mean the valves got damaged?
Sep 13, 2016 at 4:47 PM
HMAC300
  • 48,601 POSTS
you have an interference engine so if timing belt broke pretty much some valves got damaged compression check will tell when it back together. for tdc try sliding balancer back on a little ways and see if mark lines up the mark on crank should be TDC.if you look carefully on pic that I sent the keyway for pulley is at about 11 O'clock at tdc. see other instructions i'm sending. you need to go two complete turns for tdc but do only with cams working as well or belt hooked up
Sep 14, 2016 at 6:35 AM
RONTS
  • 12 POSTS
As I explained at the start the timing belt did not break. I changed the belt when I had to change water pump. I marked the 3 sprockets before removing but not with lining up marks on cam or crank because I did not know where they were. The car ran ok for a week turn it off then went to start it up next day it would not. I had a compression test done at a local garage it was low at 30lbs.Again I still do not know when #1 piston is at TDC if I have to go two complete turns or are you saying if the mark is at arrow and keyway is at 11:00 o'clock it is TDC. What mark are you saying now on balancer and crank?
Sep 14, 2016 at 7:50 AM
HMAC300
  • 48,601 POSTS
first thing if compression is 30 psi then you probably have a bent valve at least on that cylinder. if the key way is at 11 and you can actually see the crank mark that you sent then it is more than likely at TDC if you can remove a spark plug you can stick a screwdriver in the hole be it lon gor short and should be able to feel piston to verify that it is TDC. By your own pic your crank keyway is at about 11 o clock and mark is at pointer so I would say you are at tdc. this car with 30 psi is going to run like crap and gas mileage will be poor to say the least. hopefully you can understand what I have said in this and other email.
Sep 14, 2016 at 9:31 AM
RONTS
  • 12 POSTS
Ok I will reposition timing belt once I know #1 cylinder is at top and hope for the best. Thanks
You did not explain the balancer and crank marks?
Sep 14, 2016 at 10:03 AM
HMAC300
  • 48,601 POSTS
if the balancer has a mark on it for #1 as not all do then seeif you can slide it on and see if themarks on that line up.
Sep 14, 2016 at 11:58 AM
RONTS
  • 12 POSTS
Lined up all the marks using the pinhole for a mark on crank gear. Put everything back together and started up OK. Does not sound like valves were damaged. Time will tell if I did it right. Thank you for all your help.
Sep 23, 2016 at 2:33 PM
Glad we could get it fixed please use 2CarPros.com anytime we are here to help.
Hmac300 is one of our best mechanics!
Best, Ken
Sep 24, 2016 at 4:08 PM
RONTS
  • 12 POSTS
Just one more thing that is bothering me. On the cams they click three times going around, on the right cam one of the clicks will stop and align both marks but the left did not, I had to carefully turn it to the mark without a click. Does this seem correct?
Sep 25, 2016 at 8:01 AM
HMAC300
  • 48,601 POSTS
yes
Sep 25, 2016 at 8:03 AM
RONTS
  • 12 POSTS
Great thanks again. I just have to figure out how to set timing and then I am good to go.
Sep 25, 2016 at 2:09 PM
