How hard is it to change my timing belt in a 2.0 engine automatic with overdrive before it breaks,
Apr 11, 2013 at 6:55 PM
CERTIFIED EXPERT
if you never did one, it will be tough. you need a lift to perform this as well as replacing the water pump, all pulleys and tensioners. if you set the timing wrong, you may bend valves.
