I am working on a timing chain replacement job and forgot to set TDC on Cylinder 1 before removing chain and chain tensioner. The car has a timing chain. After some time, I set TDC by putting timing cover back on and did not touch the cam sprockets. I’m not sure if I’m on the compression stroke for sure. I used the balloon trick, and the balloon blew up with air both times I did each revolution so I’m not sure if I’m on the compression. Stroke. This is an interference engine.
Jul 24, 2023 at 4:47 PM
