I had a motor mount break on my car and while I had it torn down I inspected the timing belt and saw that is needed replaced so I did. My issue is, suddenly the starter only clicks when I try to start it. Surely this does not have anything to do with the timing does it? It is a new starter. Reference to the cams aligning up, I noticed that when I move the sprockets with a wrench I have a spring action effect and it goes past the timing marks. Can I move the cam a little to align them? Last question is the crankshaft alignment. Not sure if I am getting this correct although from the diagram it appears I am.
Dec 4, 2017 at 7:41 PM
