Timing adjustment information needed
1993 ACURA LEGEND
200 MILES • 2.3L • 6 CYL • 2WD • AUTOMATIC
FUNKYDABS
How do I adjust the timing on my car.
Oct 22, 2016 at 11:38 AM
JIS001
  • 3,412 POSTS
Is your engine a 3.2L? If it is do you have a fax number to fax the instructions over to you? Kind of hard to post instructions and images for step by step instructions.
Oct 22, 2016 at 7:10 PM
FUNKYDABS
No I do not, just a gmail [email protected]. I just put a timing and new water pump in because my car was over heating and I took the thermostat out and put a new radiator and my car still gets hot. the fans come on and everything. I do not know what it is.
Oct 23, 2016 at 10:38 PM
Sure here you go,
Turn ignition off. Remove ACG fuse (No. 15, 7.5-amp) from under dash fuse box for 10 seconds to reset ECM. Check ECM for fault codes. If Code 18 is not present, problem is intermittent. Check for poor connections at ECM connector and ignition timing adjuster connector. Test drive vehicle and retest.
If Code 18 is present, turn ignition off. Disconnect ignition timing adjuster 3-pin connector from control box. See Fig 1 . Measure resistance between terminals "A" and "C" of ignition timing adjuster.
Fig 1: Locating Ignition Timing Adjuster Connector
G91F16290
Courtesy of AMERICAN HONDA MOTOR CO., INC.
View Full-Screen
Resistance should be 3500-6500 ohms. If resistance is as specified, go to step 4. If resistance is not 3500-6500 ohms, replace ignition timing adjuster.
Measure and record resistance between terminals "A" and "B" on timing adjuster side of harness connector. Measure and record resistance between terminals "B" and "C" on same side of connector. Add both resistance values together.
If total resistance value is not 3500-6500 ohms, replace ignition timing adjuster. If resistance is 3500-6500 ohms, turn ignition on. Measure voltage between Yellow/White (+) and Green/White (-) wire terminals on wiring harness side of connector. If voltage is about 5 volts, go to step 8.
If voltage is not about 5 volts, measure voltage between ground and Yellow/White wire terminal. If voltage is about 5 volts, repair open in Green/White wire between ECM terminal D22 and ignition timing adjuster connector.
If voltage is not about 5 volts, turn ignition off. Connect ECM Test Harness (07LAJ-PT3010A ) between ECM and ECM connectors. See Figure . Turn ignition on. Measure voltage between test terminals D20 (+) and D22 (-). If about 5 volts are present, repair open in Yellow/White wire between ECM terminal D20 and ignition timing adjuster. If voltage is not about 5 volts, replace ECM and retest.
If voltage between Yellow/White and Green/White wire terminals in step 5 was about 5 volts, turn ignition off. Reconnect ignition timing adjuster connector. Connect ECM Test Harness (07LAJ-PT3010A ) between ECM and ECM connectors. See Figure .
Turn ignition on. Measure voltage between ECM terminals D8 (+) and D22 (-). If voltage is not 0.5-4.5 volts, repair open or short in Blue/Yellow wire between ECM connector terminal D8 and ignition timing adjuster. If voltage is 0.5-4.5 volts, replace ECM and retest.
IDLE SPEED & IGNITION TIMING
Ensure idle speed and ignition timing are set to specification. See IDLE SPEED SPECIFICATIONS and IGNITION TIMING tables. For adjustment procedures, see ADJUSTMENTS article in this section.
Application RPM
Integra
1.7L (1) 750-850
1.8L (1) 700-800
Legend
Coupe
Automatic Transmission (1) 580-680
Manual Transmission 630-730
Sedan
Automatic Transmission (1) 550-650
Manual Transmission 600-700
Vigor (1) 650-750
(1)
Automatic transmission in Neutral or Park.
IGNITION TIMING
Application (1) M/T (2) A/T
Integra
1.7L 14-18 @ 750-850 14-18 @ 750-850
1.8L 14-18 @ 700-800 14-18 @ 700-800
Legend
Coupe 13-17 @ 630-730 13-17 @ 580-680
Sedan 13-17 @ 600-700 13-17 @ 550-650
Vigor 13-17 @ 650-750 13-17 @ 650-750
(1)
Manual transmission in Neutral.
(2)
Please use 2CarPros anytime, we are here to help and tell a friend.
Best, Ken
Oct 24, 2016 at 8:00 PM
