Being a 1996 the timing is not adjustable. It is controlled by the computer based off the base timing. There is a camshaft retard offset procedure, but you need a scan tool to do that as there is no other provisions to adjust it. For that you connect the scan tool. Go to the cam retard offset setting in the engine menu on the Tech II then once there you run the engine up to 1000 rpm and rotate the distributor until the cam retard offset reads withing 2 plus or minus degrees of zero. With zero being "perfect". There are no other adjustments and even the cam offset isn't really needed unless you removed the distributor.
Feb 4, 2025 at 5:49 PM
