So I just did head gasket, 2.3 car is running almost awesome, almost. After about thirty minutes when I stop and then go at a light, there is a slight hesitation and then bam, off like a rocket! I set the timing at T.D.C. and like I said it runs great and as well starts instantly. But when I put timing light on it shows crank pulley at about eighteen or just above the T.D.C. mark on cover. Can I set cam at T.D.C. setting, loosen belt, and then just take crank back towards the mark where timing light indicates? Just before T.D.C. Thanks for any advice on tweaking the timing if it can be done. Also it is a dual coil setup.
May 15, 2021 at 3:37 PM
