Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Mazda
b2500
Engine
Timing Belt
Replace/Remove
After replacing a broken timing belt, the engine loses power and has a high idle when the clutch is engaged?
1999 MAZDA B2500
175,000 MILES • 2.3L • 4 CYL • 2WD • MANUAL
JAMIEGILLIAM06
MEMBER
FOLLOW
The engine losing power in 4-5 gear and idles high when clutch is in, just replaced broken timing belt.
Apr 26, 2023 at 7:59 PM
CERTIFIED EXPERT
This happens when the timing belt is off one tooth.
Here is a guide to help you double check the timing belt marks:
https://www.2carpros.com/diagrams/mazda/b2500/1999
Apr 27, 2023 at 4:51 PM
