after replacing intake gaskets i cannot get the distributor to set right
1996 GMC C1500
135,000 MILES • 5.0L • V8 • RWD • AUTOMATIC
SHAWNTEL DRIGGS
I replaced intake gaskets and cannot seem to get the distributor set right. also, when if ran at idle it died all on its own. I did not touch it, shift it nothing.
Oct 10, 2016 at 9:51 PM
HMAC300
  • 48,601 POSTS
you need a scanner to get distributor set to correct position if you did not mark it. a mechanic will have to do it with a scanner.
Oct 11, 2016 at 5:49 AM
