Hi and thanks for using 2CarPros.com
Here are the directions specific to your vehicle for removal and replacement of the distributor. The attached pictures correlate with these directions.
REMOVAL
1. Remove the screws securing the distributor cap and remove the cap.
2. Remove the bolt securing the distributor.
3. Disconnect the crank angle sensor connector and remove the distributor.
INSTALLATION
Timing Mark
Pic 1
1. Turn the engine over until #1 cylinder (front) is at TDC compression stroke.
(pic 2)
2. Install the distributor, making sure the rotor is aligned as shown when fully seated.
3. Install the distributor securing bolt and tighten slightly.
4. Connect the crank angle sensor terminal.
5. Install the distributor cap and tighten the screws.
6. Refer to ADJUSTMENT PROCEDURES and adjust the timing.
Let me know if this helps or if you need more information.
Nov 9, 2018 at 5:54 PM
