All i need to know is how do i reset the timing on my vehicle listed above.
May 27, 2021 at 9:11 AM
CERTIFIED EXPERT
Good afternoon,
I attached the procedure for the timing belt and the marks that need to be aligned.
If your belt moved, once you install the belt, you will have to do a compression test to be sure there are no damaged valves as this is an interference motor.
