Hi, I did a upper engine replace heads new, timing chain, oil pump. All back together no compression. Did leak down all cylinder all at 25 to 30%.
TDC I have the timing mark on crank on top and cam mark at bottom. Should the cam mark be at top also, on TDC
As of now when I rotate the engine so the timing mark on crank is at top and the cam mark is at top the exhaust valve on number one starts to open.
I think I may have the timing 180 degrees out.
Please help. Thanks, Tony
PS. When I first finish this I started the engine it ran smooth let it warm up in shop checked all fluid levels all okay. So I drove the truck for about 1/4 mile that is when it stopped. Towed it back to shop that is when I checked the compression and had none. I was also thinking that maybe the heads are machine wrong where the rocker arm shaft mount. Thinking maybe the lifters build up with oil and now valves are opening to soon maybe I just beside myself with this.
I am sixty five years old started working on cars when I was old enough to hand my dad wrenches. I have a home shop and do a lot of car repairs.
Thanks again
Thanks again
Sep 26, 2018 at 4:07 PM
