tilt steering wheel
1977 CHEVROLET CORVETTE
59,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
VIPER_1953
This is my very first Corvette. It looks like it has tilting steering wheel. How do I get it to tilt?
Jul 23, 2017 at 6:13 PM
STEVE W.
  • 15,113 POSTS
Look at the left side of the column. There should be two stalks, the top one will be the turn/dimmer/cruise lever. Below it will be a shorter lever, that is the tilt lever, just pull it toward the wheel the same way the dimmer works, with it pulled the wheel will move up/down. Release it where you wish, and tilt the wheel a bit and it will lock in again.
Jul 23, 2017 at 6:48 PM
WRENCHTECH
  • 20,761 POSTS
It probably has a telescopic column also. Turn the lock counterclockwise at the center of the steering wheel and the wheel will go in and out.
Jul 23, 2017 at 7:58 PM
