Are the tie rod ends loose or failing? Normally that is the only time you replace them, not age or mileage but when they have actual play in them. The rear links are the same way, they are only used to adjust the rear toe and don't normally wear out. However, they are easy to check. Jack up the front (or rear for the back) so you can see and watch the steering. Now have someone try to turn the tire by pushing and pulling on it on the outside. What you are looking for is play in the steering parts 1 2 and 3 So say you can see part 1 not moving but the tire can turn in and out an eighth of an inch, that would be wear that you want to replace the parts for, or if you can see the boot moving but the steering wheel is stationary, that could mean the inner joint 3 is worn. For the rear you do the same thing while watching part 5.
For instance, the front and rear links will be similar to the first picture in this guide. What you are looking for is movement in the upper steering knuckle, without movement in the lower part, which would show wear. If there is none, they are okay.
https://www.2carpros.com/articles/tie-rod-end-replacement
The attached are the images for your front and rear suspension. The parts you are talking about are 1,2 and 3 on the front and part 5 in the rear. However, for the front end you might be better off replacing the entire rack rather than the individual joints. That is because the entire rack can be replaced in about 3 hours while replacing both inner tie rod ends alone is a 4-hour job. Replacing the complete rack gets you all new inner and outer parts and boots as well as replacement steering fluid.
Part price wise it is a bit more, but you get all new wear items and pay less in labor overall.
The rack is part # 26044316 and a rebuilt unit runs about $250.00 from Rock Auto (local parts store is going to be more) You then add the price of outer rod ends (about $20.00 each).
For the rear there are inner and outer links that allow adjustment, but if you are not seeing odd tire wear and testing shows no movement, they are fine.
I don't like to see folks spend money on items that are really not needed. So, I would check them myself. Oh, and FYI, find a nice independent shop, many of the chain places will "upsell" on anything they can. Not saying that is the case but a good local independent is usually better.
Apr 6, 2025 at 6:59 AM
