I was replacing the struts and when I got to the tie rod, and sway bar as I am tightening the nut it spins with the stem there for I am not getting anywhere. I have tried using a C clamp, using a jack to push the tie rod up into the knuckle. I have researched and found that a certain tie rod puller can also be used as a clamp to stop it from spinning. Before I spend the money on that I wanted to know if there is another way to do it? I cannot even get the nut off at the moment. I have also noticed that when I did put the nut on and started turning that it stiffened up as if it had attached itself to the stem. Could it be seized?
May 20, 2018 at 11:41 PM
