The tie rods usually have a torque range. My SOP is to tighten them to the minimum torque, then see if any of the holes line up? If yes, install the pin. If not you can still tighten it within the spec until they do line up. FYI the "fixing nut" on yours has a torque spec of 24-33 Nm ( 18-24 ft lb) Just don't go to the top number first, you don't really want to back off if possible.
Mar 14, 2026 at 11:49 AM
