TID: $04 CID: $60?
2015 DAEWOO NEXIA
97,000 MILES • 1.5L • 4 CYL • 2WD • MANUAL
AKMAL BOOMER
Hello, please help me, my Torque car gives such an error.
TID: $04 CID: $60
High sensor voltage for switching time calculation
TID: $07 CID: $4d
Minimum sensor Voltage for test (calculated) okay.
Mar 23, 2023 at 2:16 AM
The error codes you mentioned are related to the OBD-II system of your car. The first code (TID $04 CID $60) indicates that there is a high sensor voltage for switching time calculation. This could be caused by a malfunctioning sensor, wiring issue, or a problem with the engine control module (ECM).
The second code (TID $07 CID $4d) indicates that the minimum sensor voltage for the test (calculated) is okay. This means that the minimum voltage required for the test has been met.
I would check the alternator voltage output it seems like it might be overcharging the system.
Here is a guide that will help:
Please go over this guide and report back.
Mar 23, 2023 at 9:33 AM
AKMAL BOOMER
Sorry you answered me ECM on this post:
https://www.2carpros.com/questions/2004-chevrolet-optra-high-sensor-voltage-switch-time-calculation-problem
told ICM which one is correct?
Mar 24, 2023 at 9:25 AM
These are two different cars? I am not sure what you are asking?
Mar 26, 2023 at 12:22 PM
