Hi, I've posted about my issue before but now I have audio.
Car listed above CXS model, 4.6L Northstar V8.
Problem: My car makes a ticking sound when accelerating. It appears to be coming from the engine. The ticking doesn't occur at idle. The sound doesn't start until I drive the car for more than 30 minutes. The sound goes away as soon as I let go of the gas peddle. For some reason when I put on the cruise control and the car accelerates at the same RPM, the sound is gone. Maybe that's a coincidence but 90% of the time cruise control is on the noise immediately goes away, even when it's at the same RPM. The noise occurs at any RPM as soon as I press the gas.
More info: I've kept up on oil changes. I'm using 93 Octane gas. I've driven the car normally. I don't notice any mechanical side effects of the noise. I tried a Seafoam treatment and nothing changed. No check engine light.
Links:
[Revving](https://youtu.be/iz7x__kaoMs)
[Driving normally Loudest](https://youtu.be/E1Kite6mg1s)
[Hard acceleration](https://youtu.be/WS1wA5FSd5k)
Don't mind the speed limited to 80 message, ride height sensor is out. The sound is really obvious in the one where I'm driving down the street.
Links:
Feb 6, 2020 at 9:15 AM
