ticking noise in fuse area under dash
2001 JEEP GRAND CHEROKEE
200 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
KNKIGHTNET
Have vehicle with ticking noise under dash, that if left will drain the battery. Put a new battery in and found the ticking again. unplugged the battery to save the battery. will start and drive, but ticking noise if left will drain battery. Replacing battery connectors as a possible solution. Any suggesting would be helpful.
Feb 27, 2018 at 10:53 AM
HARRY P
  • 2,292 POSTS
Ticking could be a bad hazard flasher or turn signal flasher maybe. Do those work normally?
Feb 27, 2018 at 11:18 AM
