Ticking noise from engine?
2013 CHRYSLER 300
125,000 MILES • V8 • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,008 POSTS
I know the ticking is common in Dodge and Chrysler vans, and i have replaced many lifters. Never dealt with the Hemi ticl. Is it pretty much the same? I also read that up to 09 is different than 09 and up. I am sure you have seen this before. Any recommendations?
Oct 10, 2022 at 12:01 PM
BHAMDOC1973
  • 2,008 POSTS
Also, the noise gets better after it's warmed up.
Oct 10, 2022 at 12:04 PM
Can you please upload a video of the noise?
Oct 10, 2022 at 4:42 PM
BHAMDOC1973
  • 2,008 POSTS
I'll get you one tomorrow.
Oct 10, 2022 at 5:09 PM
BHAMDOC1973
  • 2,008 POSTS
These two when cold. I'll add another once she is warm. Thanks
Oct 11, 2022 at 10:15 AM
BHAMDOC1973
  • 2,008 POSTS
Warm.
Oct 11, 2022 at 10:28 AM
Thanks for the videos. That is definitely valve train noise, I would remove the driver's side valve cover and look for loose valve train, remember to rotate the engine over so you can check all valve train components. Upload videos of the problem when you find it. It sounds like a roller rocker arm has fallen apart.
Oct 11, 2022 at 1:17 PM
BHAMDOC1973
  • 2,008 POSTS
I am hoping so, and yes it seems to be coming from the driver's side. I replaced many in the past so this is an easy job if it is. Thanks
Oct 11, 2022 at 1:29 PM
Yep, that has been a problem, let me know what you find.
Oct 12, 2022 at 6:31 PM
BHAMDOC1973
  • 2,008 POSTS
I removed the driver's side. There is play as you see in the video. Can you give instructions on replacing those? I did it before on a 2.7l motor, which comes as a whole set and it wasn't too bad.
Oct 15, 2022 at 6:16 AM
BHAMDOC1973
  • 2,008 POSTS
Also online looking at them they just say exhaust or intake, are they the same fit for both driver and passenger? They don't specify.
Oct 15, 2022 at 6:43 AM
Yes, that are the same for both sides, here is how the rocker shafts and arms are replaced. Check out the images (below). Let us know what happens and please upload pictures or videos of the problem.
Oct 15, 2022 at 12:49 PM
BHAMDOC1973
  • 2,008 POSTS
what is the torque on the bolts?
Oct 15, 2022 at 1:49 PM
3. Install the rocker shaft assemblies in the same order as removed.
4. Using the sequence shown, tighten the rocker shaft bolts to 22 Nm (16 ft. lbs.).
Oct 16, 2022 at 2:02 PM
BHAMDOC1973
  • 2,008 POSTS
Replaced intake and exhaust rocker assemblies. Still ticking.
Nov 4, 2022 at 9:06 AM
BHAMDOC1973
  • 2,008 POSTS
I can't tell.
Nov 4, 2022 at 9:09 AM
BHAMDOC1973
  • 2,008 POSTS
Or is this normal? I'm not sure if I am just way tuned to it because if i hear any tick i assume it's ticking. I know there are some normal ticking on all hemi's. I can't tell any more.
Nov 4, 2022 at 9:43 AM
So, this engine has roller lifters that can fall apart, If the rockers look okay, I would check out the lifters,
Check out this video:
https://youtu.be/XHqSePuaD-M
Nov 5, 2022 at 11:44 AM
BHAMDOC1973
  • 2,008 POSTS
I have not seen any roller lifters, where are they located? Also, am hearing most of the noise from around the intake, like under the intake.
Nov 5, 2022 at 11:54 AM
BHAMDOC1973
  • 2,008 POSTS
Also, how would you check on exhaust broken bolts? It's so tight. I read a couple of places that it's a common issue. But how would that cause a tick? Also, i noticed the tick is more pronounced when its warm now.
Nov 5, 2022 at 12:16 PM
The lifters are under the intake manifold. You will need to remove the cylinder heads to replace them. To check on exhaust broken bolts use a flashlight from the bottom you may need a small mirror to aid the inspection.
Nov 7, 2022 at 11:10 AM
BHAMDOC1973
  • 2,008 POSTS
Removed driver side. Found one collapsed. Can you help me with the part number?
It's on the front mds section.
It's the 3rd one in the picture in order from front to back.
I assume other than the difference between the two types for being mds with a hole and non mds, nothing else is different and the rear ones are same as front?
Nov 9, 2022 at 12:26 PM
Good find It looks like the camshaft will be bad as well, here is the part number for the lifters.
Front
14 - With Valve Lifters
5038785AD
$264.00
14 - Without Valve Lifters
53021727AC
$5.95
Rear
5038786AD
$264.00
53021729AC
$12.70
Let me know how it goes.
Nov 10, 2022 at 9:37 AM
BHAMDOC1973
  • 2,008 POSTS
I am just going to change the one lifter and see, don't want to fool with cam.
Nov 10, 2022 at 9:41 AM
It will work for a little while.
Nov 12, 2022 at 9:06 AM
