Ticking noise after replacing timing chain
2010 KIA FORTE
101,240 MILES • 2.0L • 4 CYL • 2WD • MANUAL
REDBONE
  • 105 POSTS
I just replaced the timing chain in my car because i had a slight slapping noise. found out the timing chain tensioner was weak.After replacing the timing chain the car started right up with no slapping sound, but now i have a ticking noise. The car hasn't been driven for two years. could i have a sticky lifter and what can i do to get rid of the ticking? Never had that noise before.
Jul 13, 2019 at 1:40 PM
BRANDON SIMON
  • 49 POSTS
The ticking could be a stiff or unlubricated lifter, but it can also be the timing being off by as little as one tooth. Please be sure the timing is set 100% TDC, because timing being off by even the smallest little bit can cause engine noises, especially in a 4 cylinder car. Please keep us posted!
Jul 13, 2019 at 3:41 PM
REDBONE
  • 105 POSTS
i will double check the timing again. if timing is correct, how can i get the lifter to stop ticking or will the lifter noise gradually go away?
Jul 14, 2019 at 10:23 AM
I would change the oil and filter to a lighter weight such as 5/20
Fluid Type
API Classification .................... API service SJ, SL/ILSAC GF-3 or above
Viscosity .................... SAE 5W-20, 5W-30
Capacities
Engine Oil Capacity
With filter .................... 4.5 qt (4.3L)
Here is a guide to walk you through the oil change
https://www.2carpros.com/articles/how-to-change-engine-oil-and-filter
Jul 16, 2019 at 10:39 AM
REDBONE
  • 105 POSTS
I did a oil and filter change and also put new spark plugs in....If it is one tooth off wouldnt the engine spit and sputter a little or back fire ...it does none of those.I turn the key to start and it starts right away .....
Jul 16, 2019 at 10:55 AM
Can you please shoot a quick video with your phone so we can hear the noise? that would be great. You can upload it here with your response.
Jul 17, 2019 at 11:21 AM
REDBONE
  • 105 POSTS
This is the noise after putting new timing chain in.The car sat in driveway for 2 yrs. without starting it.
Jul 17, 2019 at 1:10 PM
Thanks for the video, something is wrong inside, oil etc will not help. It sounds like a broken valve spring, valve train issue. Can you tell if the noise is coming from the front of the engine or from up top? Lets remove the valve cover to inspect. Look for loose cam followers. let me know
Jul 18, 2019 at 9:13 AM
REDBONE
  • 105 POSTS
The noise is coming from the top,driver side close to the cam sensor,will i have to take the camshaft out to fix it.
Jul 18, 2019 at 11:19 AM
Something is broken/loose/worn. please send another video when you get it apart so I can see what is going on. :)
Jul 19, 2019 at 4:49 PM
