Hi Allen,
Can you post a recording of the noise? You're thought track is correct as if it was low on oil and it sounds like it is the top end, then most likely it is lifters. More than likely when the oil was low, one or more of the lifters collapsed and has not pumped back up.
There are some "tricks" to see if they can pump back up but they are not usually successful. The most common one is to run the vehicle at high RPM for short bursts while in park. This will increase oil pressure and may force some oil in and pump it back up. The other is to use some oil additive that is for ticking noises.
A recording of the noise will help me feel more confident about that.
Let me know and we can go from there.
Jun 18, 2019 at 12:36 PM
