I do nof have a DBRIII to do an ugh readings on. I do have a OBD scan tool. This is what it is showing me: P0353 $10 (Generic) Ignition Coil C Primary/Secondary Circuit. And P0356 $10 (Generic) Ignition Coil F Primary/Secondary Curcuit.
I turn mh key 3 times to read the codes and it also shows P0353 and P0356. I need to be clear on the flashing check engine light. It actually takes a few seconds until it BLINKS. I turn the key to the on position and the check engine light is solid for a few seconds then it will start blinking 11 times and then blinks quickly for the 12th and stays solid. I have put new spark plugs in on all cylinders and I have replaced just the COPs that are in question the 3rd and 6th COP. There is no sign of white lines on the old Coils or any white on the old plugs. I have the new plugs gaped at .040 as said in the picture above, and they are torqued to specification. I'm confused by the codes that you said p0303 and p0306. My scan tool does not show those codes. Are those codes for the fuel injectors i am not sure. Any way i am still having the same problem codes pop up even after I changed the plugs and the two COP's. Is there any other tests I can attempt without having a DRBIII or am I bumming?
Mar 8, 2020 at 10:36 PM
