Thud a few seconds after accelerating after letting off gas
1988 OLDSMOBILE 98
100,000 MILES • 3.8L • V6 • FWD • AUTOMATIC
DHAYDEN10
My car recently has leaked a bit of transmission fluid. I replaced the fluid and put some conditioning fluid in it but it is still doing something funny. No matter how fast I am going thirty to seventy mph whenever I let all the way off the gas and then hit the gas again, about three seconds later there is a thud coming from underneath my car. It is not as bad the harder I press the gas but it happens pretty much every time.
May 22, 2017 at 10:53 AM
HMAC300
  • 48,601 POSTS
it may be the torque converter clutch kicking in and out have a transmission professional look at this or it is something like an axle worn he can check both.
May 22, 2017 at 12:26 PM
DHAYDEN10
Just did. he said it was the torque converter and that the stop leak stuff actually probably caused it. I am going to have him change the fluid and filter and see if that fixes the problem. If not I will probably need a new one.
May 22, 2017 at 1:05 PM
HMAC300
  • 48,601 POSTS
fluid and filter won't help more than likely it's clogged a valve partially as well as maybe ate the clutch facing off of converter.
May 22, 2017 at 3:31 PM
DHAYDEN10
So he changed the fluid and didn't see nothing scary. Ive got a drive tomorrow form Kentucky to Florida and am thinking about taking it. The new fluid didn't do much but the shudder isn't as intense as it had been. Ive had two people tell me itll probably be fine to make the drive with it. What are your thoughts?
May 23, 2017 at 7:44 PM
HMAC300
  • 48,601 POSTS
the most that will happen is it will quit working and your mileage may drop some.
May 24, 2017 at 6:36 AM
