all sensors have bee tested and all are good.....i believe pcm is bad but not showing code for pcm problems....testing egr valve and pin connector at egr ...QUESTION I HAVE....red wire at egr pin connector which supplies 12volts test with connectr (disconnected is 12 voltes) with connector installed on egr the (voltage is .005) Voltage is supplied to red wire comes from the pcm #20 pin............If there is no dead short in supply wire (red wire) i should have 12volts at red wire with pin connector installed on egr or connector open from from egr WITH IGNITON SWITCH IN ON POSITION ENGINE NOT RUNNING????????????????? AM I CORRECT?? no one will answer this question CAN YOU i believe pcm is bad..............SYMPTOMS ARE let off accelerator engine would shut off///////now engine running at 2100 rpm"s at all times with no service engine light on PLEASE HELP I AM LEANING TOWARDS NEW PCM///////CANT AFFORD PCM THEN EXPENSE FOR DEALERSHIP FLASHING OF PCM
Sep 14, 2015 at 8:33 AM
