Codes U0072, P0606, and U0101, throttle suddenly seizes?
2007 MAZDA 3
200,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
  • 45 POSTS
The vehicle moves fine, and it will suddenly seize the throttle and the RPMs will be between 1,000 and 2,000 and display AT on the dashboard? Sometimes i have to turn off the car and wait for few minutes or disconnect and reconnect the battery and it will all be fine and when i diagnose with OBD 2 scanner i get U0072 or P0606 or U0101 and i have changed almost all the sensors and throttle body including the PCM, but the problem still occurs.
Jun 2, 2023 at 12:48 PM
HOMERENORED
  • 0 POST
restroom restoration
https://pinterest.ca/homerenostoronto/
kitchen renos North York Canada
renovations Thornhill Canada
kitchen renos Richmond Hill Canada
house remodelling Thornhill Canada
renovate your bathroom North York Canada
property renovation Aurora Canada
property renovation North York Canada
new bathroom renovations Markham Canada
new bathroom remodel Toronto Canada
house remodeling Brampton Canada
house transformation Mississauga Canada
#eZ5OKAYrV5acqAeL7
Jun 2, 2023 at 1:29 PM
HAXLUDDY
  • 0 POST
https://ukrtextbook.com/
Jun 2, 2023 at 4:57 PM
HAXLUDDY
  • 0 POST
https://subject-book.com/
Jun 2, 2023 at 6:26 PM
The P0606 indicates where the problem is coming from. This isn't a sensor issue. Instead, the powertrain control module (PCM) has internal damage with a CPU.
I attached information below, but from experience, the repair has always been the replacement of the PCM.
Take a look at the attached pics and let me know if you have questions.
joe
See pics below.
Jun 2, 2023 at 9:14 PM
  • 45 POSTS
In my question, i indicated that i have changed the PCM and TCM. One new observation is that the battery light first comes on before the seizure takes place immediately after and while the seizures takes place, the battery light goes off.
Jun 2, 2023 at 10:19 PM
