I have an intermittent problem (which is getting worse) when driving at approximately 60kph where the car wont respond to throttle position. I can keep depressing the accelerator to around 60-70% position before the car accelerates.
I have had the problem for about 20000k
The Rodeo is fitted with a 6VE1 engine and manual transmission.
I have had the car on a scanner but nothing shows other than the maf sensor and throttle position sensor working but no error is recorded.
I have replaced the maf sensor, oxygen sensor, and idle stepper motor but none of these have had any effect on the problem.
May 21, 2013 at 2:44 PM
