Throttle Position Sensor going out repeatedly
1994 OLDSMOBILE 88
127,000 MILES
CHELLIEB
My car's tps sensor keeps going bad. I just took it to the shop and was told it needs replacing- it was replaced by a different shop Nov of 12, a friend did it in Feb of 12, it was replaced also early 2011, before that 2009 and also in 2006. No one has been able to give me a reason it keeps going bad other than the last time it was replaced they said there was a broken wire, so they replaced the pigtail leading to it. Here I am less than a year later and it's going bad.
A friend did an oil change and a radiator flush two weeks ago on it and also sprayed a degreaser on the engine and hosed it down. I do have a small oil leak and a coolant leak. When I parked the car to do the oil change and radiator flush it had been running fine, no check engine light. When I started it after we were done, the check engine light was on. It still ran well- smoother actually than before. A little later it randomly shut off. It did it once again a few days later, then twice yesterday. Took it to a shop today and was told my tps sensor needed replacing and my egr sensor/valve needed replacing. The egr valve had also been replaced last Nov.
Any ideas on the root cause of this repeated failure? I'm not getting any answers from the shops.
Sep 17, 2013 at 1:32 PM
SATURNTECH9
  • 30,869 POSTS
It sounds like they are not using AC Delco parts or the PCM is shorting causing the sensor to fail. I would replace the sensor first then get s used PCM for it. Please let us know what happens.
Sep 17, 2013 at 1:44 PM
SHANNON_PRIV
Thank you for this post I had this problem and had to replace the PCM cost me $80.00 all fixed! I love this site.
Jul 28, 2019 at 5:47 PM
COOP42
I am going to be changing the sensor and the repair manual I have does not have a clear diagram showing where it attaches. I was wondering if you could help me out?
Jul 28, 2019 at 5:48 PM (Merged)
CARADIODOC
  • 34,306 POSTS
Hi coop42. Welcome to the forum. The easiest thing to do is look at the new one. It's bolted to the side of the throttle body on the opposite side as where the throttle cable attaches.
What problem are you trying to solve? Throttle position sensors don't fail very often.
caradiodoc
