I am getting trouble code P0122
I put a new throttle position sensor and the code is still coming up every time I clear the code and I drive. if I turn the wheel real hard the check engine light comes right back on.
I think it is a wire broken somewhere it drives good and then when you turn the wheel the check engine light comes back on then once you reset the computer then again when you turn the wheel the lights back on then you have to reset it again.
Mar 5, 2017 at 10:52 PM
