Hello again, and thanks for the help as I'm disabled and not working with major medical issues. I need a little more info before proceeding. So, here are my questions:
1. I don't plan on taking the throttle body off. I'm going to clean it in place by removing snorkel hose out of the way.
2. Why does the battery need to be disconnected?
3. I need to make sure I don't damage the mechanism when manually opening the butterfly. When I move it all the way open will it stay there. Then after cleaning it should I put it back in the closed position before reconnecting the battery? I was told that there are gears that can get damaged if you force it open or get something out of calibration. If you open this electronic type, will you feel resistance of the gear mechanism and need to go really slow with it.
Thanks, Robert
Jul 14, 2022 at 5:52 AM
