Throttle body relearn
2013 HYUNDAI TUCSON
435,566 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
HUSSAIN1396
  • 4 POSTS
Electronic throttle body relearn.
Nov 12, 2020 at 6:42 AM
There is no specified relearn process when you replace this module. The ECM will learn the throttle position during about 20-30 seconds of idling. So what most people do after replacing this is let the vehicle idle for a couple minutes and then do a couple wide open throttle stabs and that will show it has learned the position.
I attached the information and the process on the replacement process for your review. If you want to check the operation, the inspection process is included as well with proper voltages.
Nov 12, 2020 at 8:46 AM
