Throttle
2006 FORD
35,000 MILES • 6.3L
KEITH WINTER
  • 4 POSTS
I get codes p2112, p2104, p2111,p0122, p0223,p 2104 , p2107 p2110, p2111 ,p2112 the throttle works when the engine is not running but the key ID on when I start it it will only idle
Apr 26, 2016 at 5:52 PM
HMAC300
  • 48,601 POSTS
check battery for condition including load test these may either be stored codes or battery is low sending false codes. then clear codes if battery is good an d try to run it if still same problem rescan for codes.
Apr 27, 2016 at 7:41 AM
KEITH WINTER
  • 4 POSTS
I checked the battery and it's good. I cleared the codes and rescanned it now I get p2104 and p2112 . I know the throttle actuator isn't stuck closed because it moves to wot if I didn't start it
Apr 27, 2016 at 9:40 PM
KEITH WINTER
  • 4 POSTS
I am thinking it's the throttle pedal
Apr 27, 2016 at 9:42 PM
HMAC300
  • 48,601 POSTS
both of these are gas pedal dtc's but check harness from ecm to throttle it rubs on egr pipe, rubs through and shorts out that may be all it is. if not it may be the gas pedal.
Apr 28, 2016 at 6:03 AM
KEITH WINTER
  • 4 POSTS
Another different thing happened at the same time, the emergency brake indicator doesn't come on and the slide out won't work
Apr 28, 2016 at 9:14 AM
HMAC300
  • 48,601 POSTS
have that checked by a mechanic those have to be physically checked.
Apr 28, 2016 at 9:29 AM
