Fuel pump went out , so I replaced it and now it is in limp mode . Giving a TPS not connected , camshaft sensor code and crankshaft code. When light comes on you have throttle up to 4000 rpm's but know more. When you cut the check engine light off , you have no throttle. Also, replace map sensor but you have to unplug to start car.
Oct 29, 2016 at 3:55 PM
